Print at Oct 6, 2026, 8:29:40 AM
Posted by dorin at Feb 19, 2020, 9:52:06 PM
Re: SH3S installation as described for linux in website doesn't work
@DerekvG
Let's take in the priority order:
0. Please accept my apologies. praying If I upset you, please excuse me.
1. I want & I like to help You especially because You are a linux user.
2. You've right:
-the SweetHome3D has no extension
-some of the older versions I have will don't work on every machines. eg:
--at work on intel cuore2duo not work some older version but at home on i3 2gen it work. confused
3. So let's try to fix'it:
-in terminal:
-- cd into folder where You uncompressed the 6.2 version
-- ls -l (show us the out put) Should be like this (more or less):
nea-dorin@debian:~/Sweet_Home_3D/SweetHome3D-6.2$ ls -l
total 192
-rw-r--r-- 1 nea-dorin nea-dorin 18007 iul 10 2019 COPYING.TXT
drwxr-xr-x 6 nea-dorin nea-dorin 4096 iul 29 2019 jre8
drwxr-xr-x 3 nea-dorin nea-dorin 4096 iul 31 2019 lib
-rw-r--r-- 1 nea-dorin nea-dorin 901 iul 10 2019 LICENSE.TXT
-rwxr-xr-x 1 nea-dorin nea-dorin 1078 iul 10 2019 SweetHome3D
-rwxr-xr-x 1 nea-dorin nea-dorin 904 iul 10 2019 SweetHome3D-Java3D-1_5_2
-rwxr-xr-x 1 nea-dorin nea-dorin 1139 iul 14 2019 SweetHome3D-nimbus
-rw-r--r-- 1 nea-dorin nea-dorin 11873 iul 10 2019 THIRDPARTY-LICENSE-BATIK.TXT
-rw-r--r-- 1 nea-dorin nea-dorin 8029 iul 10 2019 THIRDPARTY-LICENSE-ITEXT.TXT
-rw-r--r-- 1 nea-dorin nea-dorin 22331 iul 10 2019 THIRDPARTY-LICENSE-JAVA3D.TXT
-rw-r--r-- 1 nea-dorin nea-dorin 11519 iul 10 2019 THIRDPARTY-LICENSE-JAVA.TXT
-rw-r--r-- 1 nea-dorin nea-dorin 18399 iul 10 2019 THIRDPARTY-LICENSE-JEKSPARSER.TXT
-rw-r--r-- 1 nea-dorin nea-dorin 21381 iul 10 2019 THIRDPARTY-LICENSE-JMF.HTML
-rw-r--r-- 1 nea-dorin nea-dorin 1680 iul 10 2019 THIRDPARTY-LICENSE-SUNFLOW.TXT
-rw-r--r-- 1 nea-dorin nea-dorin 93 iul 10 2019 THIRDPARTY-LICENSE-TANGO.TXT
-rw-r--r-- 1 nea-dorin nea-dorin 8031 iul 10 2019 THIRDPARTY-LICENSE-VECTORGRAPHICS.TXT
--Then execute in terminal:
./SweetHome3D
See what's happen & let us know.
Theoretically must work but with computers You never be sure.
4. If previous attempt don't work, try a clean environment:
--in Your home rename the .eteks folder to (let say) .eteks1
(that's to not loose furniture, texture and plugins but to start with a clean environment)
--try again to run from SweetHome3D-6.2 directory:
./SweetHome3D
--let us know what happen (if something happen)
5. For version from repository I can't help You while I don't use it from version 4 (or close)
Let us know the results and provide more information if need.
PS1 I've not understand what is with version 5.4 while now we are at 6.2?
PS2 Don't worry about Your work; is steel there and You will be able to continue soon.
Again Please accept my sincerely apologies!
