Print at Aug 24, 2026, 11:41:01 PM
Posted by dorin at Feb 16, 2020, 8:31:13 PM
Re: Best to make Furniture Library Editor support .kmz format file~
345345.kmz is a special file...
Indeed! Is a compression of kml file.
kml are used for gps devices and other gps aplications.
In Your archive You have a dae file which try to locate the map on Your computer. Share it with entire world and we could see Your work and many other interesting things!
Too wasteful hard drive size.
If in this times You have a problem with storage space You could delete few HD movies or buy another SSD (anyway, all's are produced in Your country).
The real waste was the 20 MINUTES to load Your tree from kmz.
if some objects use the same texture map file, they are saved separately in the furniture library file into different files.
You could edit the mtl file to point where You want.
I don't know how to do this with dae or other kind of file made under WIN10.
A friendly advice: Don't try to make a 3D map of China with SH3D but...
Good luck!
