Print at Oct 6, 2026, 1:52:12 AM
Posted by DerekvG at Jan 31, 2020, 12:02:03 PM
Re: SH3S installation as described for linux in website doesn't work
There are no symptoms , or at least the absence of any symptoms/response or error message IS the only symptom.
First i moved the uncompressed files to a directory (as per installation instruction) such as /SH3D/
Then using Nautilus I make sure SweetHome3D is executable and I change the default to action to "Run Software" instead of "open with Gedit"
When I click it the running icon starts spinning and nothing happens
This is the content of the script that DOESN'T run for version 5.4 (but it's the same for 6.2)
#!/bin/sh
# Retrieve Sweet Home 3D directory
PROGRAM=`readlink "$0"`
if [ "$PROGRAM" = "" ]; then
PROGRAM=$0
fi
PROGRAM_DIR=`dirname "$PROGRAM"`
# Run Sweet Home 3D
exec "$PROGRAM_DIR"/jre8/bin/java -Xmx1024m -classpath "$PROGRAM_DIR"/lib/SweetHome3D.jar:"$PROGRAM_DIR"/lib/Furniture.jar:"$PROGRAM_DIR"/lib/Textures.jar:"$PROGRAM_DIR"/lib/Help.jar:"$PROGRAM_DIR"/lib/iText-2.1.7.jar:"$PROGRAM_DIR"/lib/freehep-vectorgraphics-svg-2.1.1b.jar:"$PROGRAM_DIR"/lib/sunflow-0.07.3i.jar:"$PROGRAM_DIR"/lib/jmf.jar:"$PROGRAM_DIR"/lib/batik-svgpathparser-1.7.jar:"$PROGRAM_DIR"/lib/java3d-1.6/j3dcore.jar:"$PROGRAM_DIR"/lib/java3d-1.6/j3dutils.jar:"$PROGRAM_DIR"/lib/java3d-1.6/vecmath.jar:"$PROGRAM_DIR"/lib/java3d-1.6/gluegen-rt.jar:"$PROGRAM_DIR"/lib/java3d-1.6/jogl-java3d.jar:"$PROGRAM_DIR"/jre8/lib/javaws.jar -Djava.library.path="$PROGRAM_DIR"/lib/java3d-1.6 -Djogamp.gluegen.UseTempJarCache=false -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#Installer com.eteks.sweethome3d.SweetHome3D -open "$1"
by comparison this is the sweethome3d.sh file from the installed version 4.5
that i found in /usr/share/sweethome3d
#!/bin/sh
BASEPATH=/usr/share/sweethome3d
JAVA_ARGS="-Djava.library.path=/usr/lib/jni \
-Dcom.eteks.sweethome3d.applicationFolders=$HOME/.eteks/sweethome3d:/usr/share/sweethome3d"
. /usr/lib/java-wrappers/java-wrappers.sh
find_java_runtime java6
find_jars j3dcore j3dutils vecmath batik
find_jars sunflow itext janino freehep-util freehep-io freehep-xml
find_jars freehep-graphics2d freehep-graphicsio freehep-graphicsio-svg
find_jars /usr/share/sweethome3d/sweethome3d.jar
find_jars /usr/share/icedtea-web/netx.jar
cd $BASEPATH
run_java com.eteks.sweethome3d.SweetHome3D -open "$@"
