Print at Sep 10, 2026, 3:16:46 AM
Posted by jeanmarcL at Nov 27, 2019, 4:07:27 PM
[sweethome3d 5.3] [Linux debian 9.11] erreur java au lancement : javax.media.j3d.IllegalRenderingStateException
Bonjour,
J'utilise sweethome3d 5.3 sur plateforme Intel Linux debian 9.11.
En lanceant sweethome3d dans un xterm, j'ai l'erreur suivante ....
sweethome3d&
[1] 6708
lacroix@solo:~$ Java 3D: implicit antialiasing enabled
(java:6708): dbind-WARNING **: Couldn't register with accessibility bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Exception in thread "AWT-EventQueue-1" javax.media.j3d.IllegalRenderingStateException: Can't create graphics environment for Canvas 3D
at com.eteks.sweethome3d.j3d.Component3DManager.getCanvas3D(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.getOnscreenCanvas3D(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D.createComponent3D(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D.access$200(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source)
at javax.swing.AncestorNotifier.fireAncestorAdded(AncestorNotifier.java:86)
at javax.swing.AncestorNotifier.componentShown(AncestorNotifier.java:193)
at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:180)
at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:179)
at java.awt.Component.processComponentEvent(Component.java:6371)
at java.awt.Component.processEvent(Component.java:6319)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Window.processEvent(Window.java:2025)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at org.GNOME.Accessibility.AtkWrapper$5.dispatchEvent(AtkWrapper.java:700)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Cette erreur ne semble pas bloquante au premier niveau (!) puisque l'ouverture de fichier 3D s'effectue et la visualisation également dans la fenêtre 3D. Je précise qu'il s'agit dune configuration double écrans avec second écran connecté en HDMI.
Comme indiqué dans un thread sur ce forum, j'ai également installé libqt4-opengl, mais le résultat est toujours une erreur au lancement.
Ma configuration est la suivante :
ansible@solo:~$ uname -a
Linux solo 4.9.0-9-amd64 #1 SMP Debian 4.9.168-1+deb9u5 (2019-08-11) x86_64 GNU/Linux
ansible@solo:~$ cat /etc/debian_version
9.11
ansible@solo:~$ dpkg -l |grep sweethome3d
ii sweethome3d 5.3+dfsg-2 all Interior 2D design application with 3D preview
ii sweethome3d-furniture 1.6.2-1 all Interior 2D design application with 3D preview (additional furniture)
ii sweethome3d-furniture-editor 1.20-1 all Sweet Home 3D Furniture Library Editor
ii sweethome3d-furniture-nonfree 1.6.2-2 all Interior 2D design application with 3D preview (additional non-free furniture)
ii sweethome3d-textures-editor 1.5-1 all Sweet Home 3D Textures Library Editor
ansible@solo:~$ dpkg -l |grep java
ii ca-certificates-java 20170929~deb9u3 all Common CA certificates (JKS keystore)
ii java-common 0.58+deb9u1 all Base package for Java runtimes
ii java-wrappers 0.1.28 all wrappers for java executables
ii javascript-common 11 all Base support for JavaScript library packages
ii libapache-pom-java 10-2 all Maven metadata for all Apache Software projects
ii libatk-wrapper-java 0.33.3-13+deb9u1 all ATK implementation for Java using JNI
ii libatk-wrapper-java-jni:amd64 0.33.3-13+deb9u1 amd64 ATK implementation for Java using JNI (JNI bindings)
ii libavalon-framework-java 4.2.0-9 all Common framework for Java server applications
ii libbatik-java 1.8-4+deb9u1 all xml.apache.org SVG Library
ii libbcmail-java 1.56-1+deb9u2 all Bouncy Castle generators/processors for S/MIME and CMS
ii libbcpkix-java 1.56-1+deb9u2 all Bouncy Castle Java API for PKIX, CMS, EAC, TSP, PKCS, OCSP, CMP, and CRMF
ii libbcprov-java 1.56-1+deb9u2 all Bouncy Castle Java Cryptographic Service Provider
ii libbsf-java 1:2.4.0-5 all Bean Scripting Framework to support scripting languages in Java
ii libcommons-io-java 2.5-1 all Common useful IO related classes
ii libcommons-logging-java 1.2-1 all common wrapper interface for several logging APIs
ii libcommons-parent-java 39-3 all Maven metadata for Apache Commons project
ii libfontbox-java 1:1.8.12-1 all Java font library
ii libfop-java 1:2.1-6 all XML formatter driven by XSL Formatting Objects (XSL-FO.) - libs
ii libfreehep-export-java 2.1.1-3 all FreeHEP Export and Save As Library
ii libfreehep-graphics2d-java 2.1.1-5 all FreeHEP 2D Graphics Library
ii libfreehep-graphicsio-java 2.1.1-4 all FreeHEP GraphicsIO Base Library
ii libfreehep-graphicsio-svg-java 2.1.1-4 all FreeHEP Scalable Vector Graphics Driver
ii libfreehep-graphicsio-tests-java 2.1.1+dfsg1-4 all FreeHEP GraphicsIO Test Library
ii libfreehep-io-java 2.0.2-5 all FreeHEP I/O library
ii libfreehep-swing-java 2.0.3-4 all FreeHEP swing extensions
ii libfreehep-util-java 2.0.2-6 all FreeHEP utility library
ii libfreehep-xml-java 2.1.2+dfsg1-4 all FreeHEP XML Library
ii libitext-java 2.1.7-11 all Java Library to create and manipulate PDF on the fly
ii libjanino-java 2.7.0-2 all runtime compiler for Java expressions - library
ii libjas-plotter-java 2.2.6+dfsg1-3 all JAS(2) Plotter graphic library
ii libjava3d-java 1.5.2+dfsg-11 all Java 3D API (java library)
ii libjava3d-jni 1.5.2+dfsg-11 amd64 Java3D API (java jni library)
ii libjavascriptcoregtk-4.0-18:amd64 2.18.6-1~deb9u1 amd64 JavaScript engine library from WebKitGTK+
ii libjaxen-java 1.1.6-1 all Java XPath engine
ii libjaxp1.3-java 1.3.05-2 all Java XML parser and transformer APIs (DOM, SAX, JAXP, TrAX)
ii libjdom1-java 1.1.3-1 all lightweight and fast library using XML
ii libjline-java 1.0-2 all Java library for handling console input
ii libmail-java 1.5.6-2 all JavaMail API Reference Implementation
ii libnb-org-openide-util-java 8.1+dfsg1-5 all Utility classes from the NetBeans Platform
ii libnb-org-openide-util-lookup-java 8.1+dfsg1-5 all Utility lookup classes from the NetBeans Platform
ii libreoffice-java-common 1:6.1.5-3+deb10u4~bpo9+1 all office productivity suite -- arch-independent Java support files
ii librhino-java 1.7.7.1-1 all Libraries for rhino Java Script Engine
ii libsaxon-java 1:6.5.5-10 all Saxon XSLT Processor
ii libsunflow-java 0.07.2.svn396+dfsg-14 all rendering system for photo-realistic image synthesis
ii libtablelayout-java 20090826-3 all Java layout manager for creating user interfaces fast and easy
ii libvecmath-java 1.5.2-5 all javax.vecmath vector math package
ii libxalan2-java 2.7.1-9 all XSL Transformations (XSLT) processor in Java
ii libxerces2-java 2.11.0-7 all Validating XML parser for Java with DOM level 3 support
ii libxml-commons-external-java 1.4.01-2 all XML Commons external code - DOM, SAX, and JAXP, etc
ii libxml-commons-resolver1.1-java 1.2-7 all XML entity and URI resolver library
ii libxmlgraphics-commons-java 2.1-2 all Reusable components used by Batik and FOP
Merci d'avance pour une aide
Cordialement
