Print at Oct 5, 2026, 8:58:37 PM
Posted by jeanmarcL at Nov 27, 2019, 3:44:19 PM
Re: [sweethome3d display via ssh -X Linux Debian]
Pour compléter les tests ....
J'ai installé sweethome3d sur un portable arm64 (Pinebook) (avec 4 coeurs 64 bits), lequel est totalement opérationnel au niveau graphique pour une session locale.
La distribution est une Debian 10.2 avec les composants suivants :
jean-marc@pinebook:~$ dpkg -l |grep sweethome3d
ii sweethome3d 6.1.2+dfsg-2 all Interior 2D design application with 3D preview
ii sweethome3d-furniture 1.6.4-1 all Interior 2D design application with 3D preview (additional furniture)
ii sweethome3d-furniture-editor 1.24-2 all Sweet Home 3D Furniture Library Editor
ii sweethome3d-furniture-nonfree 1.6.2-2 all Interior 2D design application with 3D preview (additional non-free furniture)
ii sweethome3d-textures-editor 1.6-2 all Sweet Home 3D Textures Library Editor
jean-marc@pinebook:~$ uname -a
Linux pinebook 5.3.9-sunxi64 #19.11.3 SMP Mon Nov 18 19:19:00 CET 2019 aarch64 GNU/Linux
jean-marc@pinebook:~$ dpkg -l |grep java
ii ca-certificates-java 20190405 all Common CA certificates (JKS keystore)
ii java-common 0.71 all Base package for Java runtimes
ii java-wrappers 0.3 all wrappers for java executables
ii libactivation-java 1.2.0-2 all JavaBeans Activation Framework
ii libapache-pom-java 18-1 all Maven metadata for all Apache Software projects
ii libbatik-java 1.10-2 all xml.apache.org SVG Library
ii libbcmail-java 1.60-1 all Bouncy Castle generators/processors for S/MIME and CMS
ii libbcpkix-java 1.60-1 all Bouncy Castle Java API for PKIX, CMS, EAC, TSP, PKCS, OCSP, CMP, and CRMF
ii libbcprov-java 1.60-1 all Bouncy Castle Java Cryptographic Service Provider
ii libcommons-io-java 2.6-2 all Common useful IO related classes
ii libcommons-logging-java 1.2-2 all common wrapper interface for several logging APIs
ii libcommons-parent-java 43-1 all Maven metadata for Apache Commons project
ii libfreehep-export-java 2.1.1-4 all FreeHEP Export and Save As Library
ii libfreehep-graphics2d-java 2.1.1-6 all FreeHEP 2D Graphics Library
ii libfreehep-graphicsio-java 2.1.1-5 all FreeHEP GraphicsIO Base Library
ii libfreehep-graphicsio-svg-java 2.1.1-5 all FreeHEP Scalable Vector Graphics Driver
ii libfreehep-graphicsio-tests-java 2.1.1+dfsg1-5 all FreeHEP GraphicsIO Test Library
ii libfreehep-io-java 2.0.2-6 all FreeHEP I/O library
ii libfreehep-swing-java 2.0.3-5 all FreeHEP swing extensions
ii libfreehep-util-java 2.0.2-7 all FreeHEP utility library
ii libfreehep-xml-java 2.1.2+dfsg1-5 all FreeHEP XML Library
ii libitext-java 2.1.7-12 all Java Library to create and manipulate PDF on the fly
ii libjanino-java 2.7.0-2 all runtime compiler for Java expressions - library
ii libjas-plotter-java 2.2.6+dfsg1-4 all JAS(2) Plotter graphic library
ii libjava3d-java 1.5.2+dfsg-16 all Java 3D API (java library)
ii libjava3d-jni 1.5.2+dfsg-16 arm64 Java3D API (java jni library)
ii libjavascriptcoregtk-4.0-18:arm64 2.26.2-1~deb10+1 arm64 JavaScript engine library from WebKitGTK
ii libjaxen-java 1.1.6-4 all Java XPath engine
ii libjaxp1.3-java 1.3.05-5 all Java XML parser and transformer APIs (DOM, SAX, JAXP, TrAX)
ii libjdom1-java 1.1.3-2 all lightweight and fast library using XML
ii libmail-java 1.6.2-1 all JavaMail API Reference Implementation
ii libnb-org-openide-util-java 10.0-2 all Utility classes from the NetBeans Platform
ii libnb-org-openide-util-lookup-java 10.0-2 all Utility lookup classes from the NetBeans Platform
ii librhino-java 1.7.7.1-1 all Libraries for rhino Java Script Engine
ii libsunflow-java 0.07.2.svn396+dfsg-17 all rendering system for photo-realistic image synthesis
ii libtablelayout-java 20090826-4 all Java layout manager for creating user interfaces fast and easy
ii libtagsoup-java 1.2.1+-1 all SAX-compliant parser for real-life HTML
ii libvecmath-java 1.5.2-7 all javax.vecmath vector math package
ii libxalan2-java 2.7.2-2 all XSL Transformations (XSLT) processor in Java
ii libxerces2-java 2.12.0-1 all Validating XML parser for Java with DOM level 3 support
ii libxml-commons-external-java 1.4.01-3 all XML Commons external code - DOM, SAX, and JAXP, etc
ii libxml-commons-resolver1.1-java 1.2-9 all XML entity and URI resolver library
ii libxmlgraphics-commons-java 2.3-1 all Reusable components used by Batik and FOP
En lanceant sweethome3d dans la session courante, donc sans déport X11, le problème est identique concernant l'affichage, ce qui indique donc que le sujet n'est plus (ou pas pour le moment) sur le déport X11 via le ssh -X ou ssh -Y.
Merci d'avance de votre aide
Cordialement
