Print at Sep 6, 2026, 2:43:15 PM
Posted by SeppoV12 at Nov 24, 2019, 11:18:36 AM
Re: Pan in aerial 3d view
Two ways to set the height of the virtual viewer:
1. double click virtual visitor icon and in opening window set 'Eyes elevation' value other than default (170 cm)
2. Use menu for that: 3D view - Modify virtual visitor...
When you handle very large objects, virtual visitor is often hard to find. In this case method 2 is always possible.
Tip: if you want to see if pillow is on top of bed (height 45 cm) or floating above it, go close and set Eyes elevation bit more than bed height (=>46 cm).
Then (if necessary) adjust pillow elevation for realistic value, for example 44.5 cm.
