Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Two level with the same elevation: some rooms on upper level are transparent » » » » Post: Re: Two level with the same elevation: some rooms on upper level are transparent |
Print at Oct 14, 2026, 11:05:53 PM |
| Posted by Puybaret at Oct 28, 2019, 10:39:47 AM |
Re: Two level with the same elevation: some rooms on upper level are transparent I tried to fix the problem shown in the 3D view of your last image many times, and unfortunately there are still a few cases where it doesn't work. It's a problem about cutting the ground with rooms to avoid them to overlap the ground. Moving the corners of the rooms may resolve the issue. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 14, 2026, 11:05:53 PM |
