Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Two level with the same elevation: some rooms on upper level are transparent » » » » Post: Re: Two level with the same elevation: some rooms on upper level are transparent |
Print at Oct 14, 2026, 11:05:34 PM |
| Posted by Gildaniel at Oct 28, 2019, 8:35:54 AM |
Re: Two level with the same elevation: some rooms on upper level are transparent Difficult to say from your screen captures. It could be a bug or simply a misunderstanding of rooms and levels. Could you post a simpler example? Dear Emmanuel, could you please check this problem? It steel exist, and there is no good solution to avoid |
Current timezone is GMT Oct 14, 2026, 11:05:34 PM |
