Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Two level with the same elevation: some rooms on upper level are transparent » » » » Post: Re: Two level with the same elevation: some rooms on upper level are transparent |
Print at Aug 21, 2026, 8:17:57 PM |
| Posted by Gildaniel at Oct 16, 2019, 1:23:05 PM |
Re: Two level with the same elevation: some rooms on upper level are transparent I think I understand what you mean. Actually, all rooms are half transparent, but when you draw a room (like the 4.27 m² one, the 1.77 m² one and the other small ones) superimposed on another larger one (like the large green one), the small rooms get less transparent. Sorry, I haven't understood your explanation, what the logic is here, why one room transparent, another not? How to get superimposed rooms always nontransparent? I see there is a trick to get nontransparent room, superimposed on lager one - at least one corner of the room should be drown outside wall contour - now room became nontransparent, then you can correct it as you wish and it retain colour. It works, but then I cannot use doubleclick for fast creation room inside walls, it was very comfortable, rapid drawing is important for me :( ![]() |
Current timezone is GMT Aug 21, 2026, 8:17:57 PM |
