Print at Aug 20, 2026, 9:30:24 AM
Posted by Bartosz at Oct 11, 2019, 8:15:58 PM
Re: Livingroom in new apartment
Good job. I especially like the models, however VeroniQ made a good point, I also noticed sun leaks. I recommend to re-doble click all your floor corners to make them match wall corners or even overlap them, then your celiling will be sealed as well. I had the same bad experience - when your main plan is not locked then it's very easy to accidently move the floor when working on models. I appreciate your work on lighting. Can you make some other angles?
