Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Issue with Imported furniture gone from library after use HELP !! PLEASE !! » » » » Post: Re: Issue with Imported furniture gone from library after use HELP !! PLEASE !! |
Print at Oct 9, 2026, 9:17:47 AM |
| Posted by Puybaret at Aug 11, 2019, 6:21:40 PM |
Re: Issue with Imported furniture gone from library after use HELP !! PLEASE !! You should have kept the models you imported somewhere, but it's not because you deleted them on your desktop that they won't appear in your catalog anymore. Imported 3D models are copied in private folders, and then in each project where you them. If you use Sweet Home 3D on another computer or under another account, the imported models won't appear in the catalog anymore there. If it's not the case, the private folder where imported items are stored depends on your operating system as explained here. Could you check what files it contains? If it contains only a file named preferences.xml, I fear that you lost them. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 9, 2026, 9:17:47 AM |
