Print at Aug 20, 2026, 9:30:23 AM
Posted by Lootza at Aug 6, 2019, 8:51:12 PM
Re: various tiles on a single wall in the bathroom
Hi, I did it similarly, I created whole-wall texture in simplest windows drawing/painting programme ("malovani" in czech), using grid and measures there, and i had the tile files as well as the wall file in pixels exactly equal to milimetres of the tile/wall.
Grouts.. just eye measurement using the grid :)
Then it is simple to put the texture on your wall, you just have to import it in correct size. (i used png format of a picture)
TIP for SPLIT walls: you do not have to create two files for one wall that is for some reason split in your 3D home, you can create one picture for the whole physical wall and put in on both parts of the wall as texture, and you can switch the BEGINNING of the wall as needed, that will alter where from does te picture start.
If you tell me how to insert pictures here, i will :xxx
L.
