Print at Sep 6, 2026, 5:11:27 AM
Posted by Mike53 at Jul 31, 2019, 11:53:20 PM
Re: Double Wall Windows and Doors
the invisible hatch is an object you can download and add to your library, search for it using the search box, top right corner of this window.
Position your window with the snap, magnetism, then use the modify function to change its depth to match the thickness of the wall, with that done use the arrow keys on your keyboard to position it in the wall
or
Disable the magnetism - file>preferences, then drag your correctly sized window into position
or
drag the window into position while holding the Alt key, this temporarily disables the magnetism
