Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: New features for 2D planning (e.g. electric installation) - prototyp available » » » » Post: Re: New features for 2D planning (e.g. electric installation) - prototyp available |
Print at Sep 20, 2026, 4:13:56 PM |
| Posted by dorin at Jul 24, 2019, 10:13:27 AM |
Re: New features for 2D planning (e.g. electric installation) - prototyp available It's an good option to lock levels with all the items not only the base plan. I use the same strategy (separate level) for emergency 2D symbols. I've try Your modified version but I need more exercise or more indications on how it work. Suggestion: add an contextual entry under level tab to lock/unlock current level or all levels except current. About the view of 2D symbols in plan: -I've set the elevation to 10cm BUT could be elevated how high You want. -Wile are symbols and appear only in 2D plan they can not be used like 3D objects. On my apartment I have plugs and switch at the same x&y but at different z. Is useless to overlap this symbols because I can distinguish nothing. -You can select all, Ctrl+x, Ctrl+v in the same place and will appear over other furniture. The last inserted is the first view. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 20, 2026, 4:13:56 PM |
