Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem with "Create photo function"/Internal Renderer » » » » Post: Re: Problem with "Create photo function"/Internal Renderer |
Print at Aug 21, 2026, 9:56:35 AM |
| Posted by csfrost at Oct 29, 2009, 6:35:21 AM |
Re: Problem with "Create photo function"/Internal Renderer Emmanuel - Thanks for both your Dev skils and your support. I am still unsuccessful with either solution. Solution #1: Excuse my ignorance, but my Vista 64 system has not 'Java' directory, so I'm unable to point to it, per your syntax. Solution #2: I have executed (I believe) precisely per your direction - a file called SweetHome3D.l4j.ini in the App directory, with the single command pasted into it. No results. Which is odd, because the modeling rendered almost a dozen times successfully before it stopped. Sometimes now the little green and red 'scanners' that paint the photo simply paint black space until it freezes. I've relaunched, rebooted... still no fix. I'm open to suggestion. Thanks again for your support. -=sf=- |
Current timezone is GMT Aug 21, 2026, 9:56:35 AM |
