Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem with "Create photo function"/Internal Renderer » » » » Post: Re: Problem with "Create photo function"/Internal Renderer |
Print at Aug 21, 2026, 9:56:15 AM |
| Posted by Puybaret at Oct 27, 2009, 11:20:52 AM |
Re: Problem with "Create photo function"/Internal Renderer Instead of entering directly "java", you have to write the full path of "java". It will probably be: C:\Program Files\Java\jre6\bin\java.exeThen the command will become: "C:\Program Files\Java\jre6\bin\java.exe" -Xmx1024m -jar path/to/SweetHome3D-x.y.jarThere's an other solution, create a text file named SweetHome3D.l4j.ini in the same directory as SweetHome3D.exe, and write the following text in that file: -Xmx1024mand relaunch Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 21, 2026, 9:56:15 AM |
