Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Cut-out for kitchen sink » » » » Post: Re: Cut-out for kitchen sink |
Print at Oct 9, 2026, 9:51:44 AM |
| Posted by hansmex at Apr 30, 2019, 6:53:04 PM |
Re: Cut-out for kitchen sink 1 - Start a new drawing, add a level with elevation 86 cms and floor thickness 4 cm; 2 - On this level draw a room that represents the shape of your counter top; forget about the sink - add colour or texture; 3 - Import a sink and mark it as "staircase"; 4 - At the lower level insert your sink - give it the correct elevation so that the top of the sink is flush with the counter top; 5 - At the top level select sink and counter top; export as OBJ (selection only) and re-import it. 6 - It works for me, so should work for you. Note: (1) assumes that the surface of your counter top is 90 cms above the floor, and that your counter top is 4 cms thick. Adjust to your needs. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Oct 9, 2026, 9:51:44 AM |
