Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Guide To Creating A Flat Roof With Cut Outs For Skylights » » » » Post: Re: Guide To Creating A Flat Roof With Cut Outs For Skylights |
Print at Sep 27, 2026, 5:17:59 PM |
| Posted by Jonnie63 at Apr 15, 2019, 10:32:11 PM |
Re: Guide To Creating A Flat Roof With Cut Outs For Skylights Additions: I did not explain the following bit very well....its about making the White liner for the hole in the roof. I wrote... "The useful thing about walls created on a level is that they start not at the top surface where you would walk but on the bottom surface of the level." Yes that is true but what I did not mention is that even before you add any height to the wall it is already as high as the floor is thick - the wall is measured in terms of its height above the top surface of the floor. If you could have a zero height wall it would in reality be as high as the thickness of the floor. If I recall you cannot have a zero height wall so the wall can be set to a height of say 0.1 cm, this means it will start at the same level as the ceiling - pass through the entire thickness of the floor ( actually our roof ) and stick above the top surface of the floor (actually our roof ) by 0.1 cm. Just remember when setting the height of the White liner that you already get the thickness of the floor ( our roof ) for free !!! |
Current timezone is GMT Sep 27, 2026, 5:17:59 PM |
