Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Set walls by interior dimensions? » » » » Post: Re: Set walls by interior dimensions? |
Print at Aug 19, 2026, 11:22:11 AM |
| Posted by paschoaal at Mar 26, 2019, 4:29:13 AM |
Re: Set walls by interior dimensions? I was having the same issue and now I believe to have found a fine workaround.. Set the wall thickness to a tiny value, like 0.01 (I use meters). That is so tiny that it will never break your measures. You add a first wall, by dragging the mouse randomly, open its dialog box and correct its coordinates for start and endpoint. Then, with magnetism enabled, you can easily create a second wall to start at the exavt endpoint of the first. Again, open the dialog box and correct the coordinates (now it should be just the endpoint). Repeat the process until you have completed the whole room. At last, with the magnetism enabled, it is also easy to set the corners for the room creation tools, sequentially. The hollow walls did not bother, in fact, I found them to be very light and clean. I also like to delete all the walls on a given side of the room, so it clears the 3d visualization from low angles. Hooe that helps. Big fan of this program. Best wishes |
Current timezone is GMT Aug 19, 2026, 11:22:11 AM |
