Print at Sep 20, 2026, 5:42:15 AM
Posted by Puybaret at Mar 13, 2019, 10:24:05 AM
Re: Exception in thread "AWT-EventQueue-0"
I already saw that problem in Sweet Home 3D. This is generally due to some objects placed at unknown coordinates (with NaN values) that prevents from computing a correct point of view. What I would like to know is how such values could happen...
Anyway, you should be able to fix it by yourself this way:
- backup your SH3D file
- edit the Home.xml file it contains with a text editor
- in the Home.xml, remove the lines containing <observerCamera> or <camera> XML elements with some attributes equal to NaN
- replace other NaN values by 0
- save the Home.xml file and reintegrate it in the SH3D file
If it doesn't work, or if you feel this is too much for you, just send me your file. I'll fix it for you.
