Print at Oct 1, 2026, 8:42:42 AM
Posted by mrpraline at Mar 4, 2019, 10:45:10 PM
Re: Doesn't launch anymore in Ubuntu 17.10
Don't know if I should start a new thread, but I cannot run Sweethome3d in Ubuntu 18.10. Both of the scripts in the download directory fail to run.
With both scripts I get:
# A fatal error has been detected by the Java Runtime Environment:
# Internal Error (os_linux_x86.cpp:291), pid=17622, tid=0xf6bccb40
# fatal error: An irrecoverable SI_KERNEL SIGSEGV has occurred due to unstable signal handling in this distribution.
# JRE version: Java(TM) SE Runtime Environment (8.0_202-b08) (build 1.8.0_202-b08)
# Java VM: Java HotSpot(TM) Server VM (25.202-b08 mixed mode linux-x86 )
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/gjbaarda/Downloads/SweetHome3D-6.1.2/hs_err_pid17622.log
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
Afgebroken (geheugendump gemaakt)
If I run the webstart version the initial window opens but then I get a pop-up window saying '3D error" and after clicking OK SH3D exits.
