Print at Sep 20, 2026, 8:40:46 AM
Posted by hansmex at Mar 2, 2019, 9:10:21 AM
Re: Installind 2D objects in walls
SH3D is made to do exactly what you are asking.
You can draw a room or building to scale, then insert furniture.
To make your own paintings, proceed as follows:
1 - select your image and note the size in cm or inch.
2 - insert a box and size it so that one face is the size of your painting, the thickness should be scaled down to, say, 5 cm or 2 inches
3 - elevate the box so that it "hangs" at the correct height
4 - select the box and do a right-click, select Modify furniture - Materials - Modify
5 - a window pops up in which you can apply a texture (=image) to all six faces of your cube; select front, then click texture
6 - a window pops up in which you can select a texture; click import, choose image, click Reduce size if it's too large, then click Continue
7 - next window appears: type a name, type or select a category, set the width to what you wrote down in step 1 (height follows automatically), click Finish
8 - click OK three times and you're done.
