Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Basement is not at set negative level » » » » Post: Re: Basement is not at set negative level |
Print at Sep 20, 2026, 2:58:09 AM |
| Posted by ottertooth at Feb 23, 2019, 9:07:03 PM |
Re: Basement is not at set negative level This is very frustrating and should not be happening because it says in the guide that you can use negative elevations. It says so right here: http://www.sweethome3d.com/blog/2018/05/04/ho..._a_split_level_house.html "The elevation of a level may also be negative to design a basement or foundations." The answer must be something really simple that I'm missing... I have raised the entire house and set the basement at 0, because I don't know what else to do. That will probably cause more issues when I have to draw the exterior landscape. Now I need to draw a pit which is below the foundation, and I can't. Not without raising all the other levels again. I also need to draw drainage and pipes that are underground and I can't do that without being able to enter negative elevations. |
Current timezone is GMT Sep 20, 2026, 2:58:09 AM |
