Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Various issue with walls/textures » » » » Post: Re: Various issue with walls/textures |
Print at Sep 20, 2026, 12:18:57 AM |
| Posted by Ceciliabr at Feb 5, 2019, 9:16:14 PM |
Re: Various issue with walls/textures I find this very strange and I don't get the logic behind. Maybe you can shed some light on this. Yes, I can.The texture coordinates are not recognised when you use the first method ( left), so the texture is applied using the predefined size. The other method will use the texture coordinates when you apply a texture, and give the texture a relative scale as described by the coordinates. Any texture , no matter the size, will be rescaled by the texture coordinates to fit the model. ![]() You have to use this method to get the result on the right: ![]() If you are changing texture you have to scale and maybe alter the x/y coordinates of your texture before you apply it to all six sides. Cec |
Current timezone is GMT Sep 20, 2026, 12:18:57 AM |
