Print at Sep 21, 2026, 5:00:04 PM
Posted by thoron at Feb 3, 2019, 11:55:27 AM
Re: Various issue with walls/textures
Thank you, Puybaret for giving some feedback.
With regard to issue 1, I tried your proposal of a small wall (see picture). Hope that this was what you mean. Apart from the need to iterate the texture of this small wall in oder to get it in line with the normal baseboard picture, would this not create a problem with the ceiling?
As far as I understood the manual/hints any wall smaller than the surrounding main walls would create strange things with the ceiling, which anyhow is another problem I have, because my house has several walls smaller than room height.
With regard to issue no. 2 I do not really get what you mean. Can you explain a little more detailed?
With regard to issue no. 3 I am as well not sure that I understand what you want to say.
I figured already out that assigning a texture when creating the model (in Sketch up) helps sometimes to overcome this issue when retexturing in SW3D with the material modification panel. But other cases e.g. the one I displayed in my first post, do not work, although it got assigned a simple color texture in Sketch up.
Regarding issue 4 any ideas or hints?
Just for my interest, when you say that these issues will not be improved soon, would the fix so difficult or do you have so many other things with higher priority?
Your help is very much appreciated.
