Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: transparent vertical and horizontal glass square » » » » Post: Re: transparent vertical and horizontal glass square |
Print at Sep 19, 2026, 11:17:18 PM |
| Posted by Mike53 at Jan 13, 2019, 3:01:52 PM |
Re: transparent vertical and horizontal glass square Without seeing the shape of your roof its hard to be certain, but it does sound like you need to use a wall, set its width and height to suit, then position ANY window with the dimensions matching your velux, export > import, set its angle, make the window invisible and then position your velux. You may need a couple of attempts at the wall height as this shortens as you angle it. Good Luck Mike |
Current timezone is GMT Sep 19, 2026, 11:17:18 PM |
