Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Window Partially above Garage door problem » » » » Post: Re: Window Partially above Garage door problem |
Print at Aug 25, 2026, 9:24:03 AM |
| Posted by Puybaret at Jan 2, 2019, 1:25:09 PM |
Re: Window Partially above Garage door problem Why do you want the window to overlap the garage door? If you want the window to make a hole in the garage door, it won't work, because only holes in walls are computed. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 25, 2026, 9:24:03 AM |
