Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to separate connected walls » » » » Post: How to separate connected walls |
Print at Sep 20, 2026, 3:17:23 AM |
| Posted by thoron at Dec 21, 2018, 4:23:46 PM |
How to separate connected walls Hello, during building my house in SH3D I figured out a problem I have no idea how to solve. As you can see in the attached picture one of my consists of three seperate walls, because the middle wall must have a different texture than the other two walls. Later I needed to change the thickness of the middle wall, because it has no outer bricks. So I changed its thickness, but due to the midpoint strategy of the programm the thickness was reduced from both sides, which is not desired. So I wanted to move the wall so that the inner part is in line with the inner part of the other two walls. Bit this is not possible, because they move together with the middle wall (see pictures). Is there any way to disconnect walls after they have been connected or is there another way how to solve this situation? ![]() |
Current timezone is GMT Sep 20, 2026, 3:17:23 AM |
