Print at Jul 27, 2026, 2:49:15 PM
Posted by okh at Dec 16, 2018, 3:35:38 PM
Re: vent issue
Checked again, and it seems to happen with double walls, one sloping, and models with cutout and that extends outside the cut wall. But it looks as if it only happens when the top part of the sloped wall is higher than the lowest part of the model.
Which means there is a workaround: use split wall so you get two connected sloping walls.
By the way, there is a more modern looking fan in Source Forge 3D models 346 (in the file: wet_room.sh3d).
