Print at Sep 20, 2026, 6:36:08 AM
Posted by delaing at Nov 18, 2018, 11:46:05 PM
Re: Draw (offset) Wall from Existing Wall?
Thanks for the suggestions; I have the plugin confirmed.
So that my primary question doesn't get lost, here it is again:
1) I am not seeing a way to "move" a wall, duplicated or original, as you describe, as an option in the Modify Walls feature. What am I missing or not understanding?
Along with this:
2) In okh's reply above. . .
I would for instance: select first wall, Ctrl+Shift Move that wall, double-click wall and enter (offset) position manually.
How do you offset the position manually?
Seems you have to know where the object is based off of the original XY home point by what I'm seeing in the Modify Walls dialog? Or not?
Thanks in advance,
Delain
