Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Export floor texture into .obj and .mtl files » » » » Post: Re: Export floor texture into .obj and .mtl files |
Print at Sep 25, 2026, 5:35:34 AM |
| Posted by avnerm at Nov 15, 2018, 4:58:45 AM |
Re: Export floor texture into .obj and .mtl files I found out that I can export the entire 3d model with the background image into an .obj file and it opens ok with e.g. meshlab What I want is to export only the floor with the background image. Option1 that I tried is to place the texture in the background image If I select the floor for export and the floor is displayed (tick Modify rooms -> Display floor), then in the exported 3d model, the background image is obscured by the floor color If I select the floor for export and the floor is NOT displayed (untick Modify rooms -> Display floor), then the floor is not exported and the exported 3d model is empty. Option2 that I tried is to place the texture as the floor texture of the room (Modify rooms -> Floor -> Texture -> Import -> Choose Image ...) But it is difficult to adjust the size of the texture such that it will cover exactly the floor, even though I specify the exact Width and Height. It would have been helpful if the floor texture would be seen in the 2d view, because then I would adjust the floor such that the texture fits it exactly. But the texture is only seen in the 3d View panel :( Is it possible to show the floor texture in the 2d view as well? Thanks, Avner |
Current timezone is GMT Sep 25, 2026, 5:35:34 AM |
