Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: No 3D view in 2.0 » » » » Post: Re: No 3D view in 2.0 |
Print at Aug 21, 2026, 7:56:55 AM |
| Posted by Puybaret at Jun 27, 2009, 8:32:00 PM |
Re: No 3D view in 2.0 Miserably, you seem not to be alone. :-( As proposed by aperezm in https://sourceforge.net/tracker/?func=detail&...id=152568&atid=784665 try to run Sweet Home 3D from its Jar file by following these instructions: 1. Install Java at http://java.com if you didn't already 2. Download http://prdownloads.sourceforge.net/sweethome3d/SweetHome3D-2.0.jar 3. Open a run dialog from Windows Start menu > Run... 4. Type the following command in one line: javaw -Xmx512m -Dsun.java2d.opengl=false -Dsun.java2d.d3d=true -Dsun.java2d.noddraw=false -Dsun.java2d.ddoffscreen=true -Dsun.java2d.ddscale=true -Dj3d.rend=d3d -jar \path\to\SweetHome3D-2.0.jar (replace "\path\to" by the real path where the file "SweetHome3D-2.0.jar" can be found) 5. Click on Ok Please report here or in bug tracker if it works or not. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 21, 2026, 7:56:55 AM |
