Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: SweetHome3D-6.0.beta12-windows.exe » » » » Post: Re: SweetHome3D-6.0.beta12-windows.exe |
Print at Sep 6, 2026, 3:45:16 AM |
| Posted by live at Oct 24, 2018, 11:40:41 AM |
Re: SweetHome3D-6.0.beta12-windows.exe >Java Web Start version No possibility to specify owns local path?? >With Java 8, the default max memory is a quarter of the available memory. Then, on http://www.sweethome3d.com/download.jsp I would change "it's not the preferred option to run Sweet Home 3D because you won't get association with Sweet Home 3D files, and depending on the Java version you use, it could use 96 MB of memory at maximum, which is too small to create middle sized homes." To something as "Warning: Java 7 bounds SH3d to maximum 96Mb, which is too small to create middle sized homes ; with Java 8, this method limits the SH3d memory usage to maximum 1/4 of the available RAM, if your system as more than 1Gb free ram, you shouldn't experience any limitation." |
Current timezone is GMT Sep 6, 2026, 3:45:16 AM |
