Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Recomputing rooms. » » » » Post: Re: Recomputing rooms. |
Print at Aug 24, 2026, 10:15:09 PM |
| Posted by Puybaret at Oct 1, 2018, 8:00:57 PM |
Re: Recomputing rooms. I've had this idea in mind for a long time, but fear that some special cases could be tricky to program or give wrong results. Maybe I should propose it only in the contextual menu of the plan, and use the point where the right click happened to help. Nevertheless, note that you could already cut the room you want to adjust, create it again then select the menu item Edit > Paste style to get the color/texture you set previously. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 24, 2026, 10:15:09 PM |
