Print at Aug 21, 2026, 9:40:18 PM
Posted by YGYL at Sep 26, 2018, 9:54:22 PM
cool   Luxurious ceiling gypsum line!!!!!
Download the file
Luxurious_ceiling_gypsum_line.sh3d
Rendered graph
Model component layout
The whole object consists of small objects. Small objects consist of smaller objects. Smaller objects consist of the left and right sides of the component.
The whole object seems to be encoded. The advantage is that it greatly reduces the disk footprint of files, whether they are furniture libraries or SH3D files.
After encoding and subtracting edges, the current file is at least 10 times smaller than the original file.Luxurious_ceiling_gypsum_line.sh3d file size is only 3.2MB!!!
It’s not for you to compress the file size of each piece of furniture to the limit, it is for you to support the user or the furniture library creator to split the compressed furniture.
Without a good method of compressing file size, there will be no good furniture library, without a good furniture library, the user experience will not be good.
I have said this before, the user's group furniture can be saved to the furniture library file. When you want to use it, just drag it from the furniture bar on the left side of the main interface to the floor plan.
If you can dynamically create complex coded group objects, that's the best thing to do. I think a lot of professionals are going to use Sweet Home 3D.
