Print at Aug 19, 2026, 11:40:41 PM
Posted by Ceciliabr at Sep 10, 2018, 12:18:18 PM
Re: The format of the chosen model isn't supported. Please chose an other model.
This sounds promising, what do you do to fix this error?
First try to rename the .mtl-file so SH3D don't see it.
If you can import the model (it will be all grey) without the .mtl-file, then you have at least located the problem.
We don't know yet if I'm right – but assuming I am:
My best advice is to open the .mtl-file of a model that you know is working, and then compare it with the non-working.
You might spot the error – or you might not.
3D builder is likely to produce the same errors again. Then you have to learn how to wash your mtl-files, or you will be stuck.
Lots of luck!
