Print at Aug 24, 2026, 10:39:22 PM
Posted by Ceciliabr at Sep 9, 2018, 10:14:35 PM
Re: Here are some notes I have made over a period of time.
I prefer to improve magnetism, even if you don't use it
Sorry for being so un-precise.
It's great that you are improving the magnetism, and I DO use it – but I only use it with the modifier [ctrl+select] because I use the alignment tool a LOT, and the alignment tool behaviour is ( just like magnetism) dependant upon what is defined as the front of an object, which is not always compatible with the desired front when using the magnetism.
So when there's a conflict due to the behaviour of the magnetism and the align-tool, I choose to define the front in accordance with the "side-by-side"- behaviour of the align tool , and then the magnetism MUST be turned OFF in preferences (to prevent unintentional snapping at the wrong angle).
Maybe your enhancements to the magnetism has something to do with this?
