Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: mtl problem » » » » Post: Re: mtl problem |
Print at Aug 21, 2026, 3:31:50 AM |
| Posted by pencilart at Mar 9, 2009, 4:34:00 PM |
Re: mtl problem Yes, as Emmanuel said, name your texture/material from within AOI and then re-export it. (Just in case you need this): From the top menu bar, go to Scene > Textures and when the dialog box pops up, click on the texture you want to change and click Edit. Then you can name it. When you re-export it, the name of the texture should now be there and the file should work. |
Current timezone is GMT Aug 21, 2026, 3:31:50 AM |
