Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to provide floor plan parameters in a file » » » » Post: Re: How to provide floor plan parameters in a file |
Print at Oct 1, 2026, 7:59:44 PM |
| Posted by Puybaret at Sep 2, 2018, 3:52:23 PM |
Re: How to provide floor plan parameters in a file The simplest way is probably to use a .sh3d extension for your file instead .xml, so the open file dialog will let you select it. You can also use a command line tu run Sweet Home 3D application followed by -open parameter and the file you want: path/to/SweetHome3D.exe -open path/to/project.sh3dBut caution, if you will save, the generated SH3D file will be at default file format, i.e. a zip file containing a Home.xml entry and other entries for images and 3D models. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 7:59:44 PM |
