Print at Aug 20, 2026, 3:27:08 PM
Posted by cbcomputer at Aug 31, 2018, 11:37:31 AM
AddLabel WebGL
Bonjour,
j'essaye d'ajouter un label dynamique apres le chargement du plugin WebGl ViewHome mais ca marche pas
pouvez vous m'aider ?
Merci
var retour = viewHome("viewerCanvas", // Id of the canvas
homeUrl, // URL or relative URL of the home to display
onerror, // Callback called in case of error
onprogression, // Callback called while loading
roundsPerMinute: 0, // Rotation speed of the animation launched once home is loaded in rounds per minute, no animation if missing or equal to 0
navigationPanel: "none", // Displayed navigation arrows, "none" or "default" for default one or an HTML string containing elements with data-simulated-key
// attribute set "UP", "DOWN", "LEFT", "RIGHT"... to replace the default navigation panel, "none" if missing
aerialViewButtonId: "aerialView", // Id of the aerial view radio button, radio buttons hidden if missing
levelsAndCamerasListId: "levelsAndCameras", // Id of the levels and cameras select component, hidden if missing
/* level: "Roof", */ // Uncomment to select the displayed level, default level if missing */
/* selectableLevels: ["Ground floor", "Roof"], */ // Uncomment to choose the list of displayed levels, no select component if empty array */
/* camera: "Exterior view", */ // Uncomment to select a camera, default camera if missing */
/* selectableCameras: ["Exterior view", "Kitchen"], */ // Uncomment to choose the list of displayed cameras, no camera if missing */
activateCameraSwitchKey: true // Switch between top view / virtual visit with space bar if not false or missing */
//r = <label level='level0' x='1222.611' y='218.17773' elevation='250.0' pitch='0.0'>
// <textStyle fontSize='100.0' />
//<text>OTA</text>
//</label>
// var l = this.createLabel(r, "test");
//this.setLabelAttributes(l, "label", r);
// this.home.addLabel(l);
setTimeout(macreationlabel, 5000,retour);
function macreationlabel(retour) {
var mylabel = new Label();
mylabel.x = '1200.00';
mylabel.y = '218.00';
mylabel.pitch = '0.0';
mylabel.elevation = '250.0';
mylabel.text = "toto";
mylabel.level = 'level0';
mylabel.setStyle("fontSize='100.0'");
this.retour.home.addLabel(mylabel);
</script>
