Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Mini Cottage » » » » Post: Re: Mini Cottage |
Print at Oct 9, 2026, 9:52:01 AM |
| Posted by AdeleAlli at Aug 11, 2018, 4:47:24 PM |
Re: Mini Cottage I really like your design, so there is very little to say. What I would have changed, probably for a different climate, is to move the fireplace downstairs. It looks a bit heavy which could complicate the floor construction. But also, if you use it, all the heat will stay under the ceiling upstairs - and it could get very worm in a small room. If you move it downstairs, heat will also rise to upper floor. ok Thank you okh. I think that this suggestion is harder to apply because I should think a way to change the plan of the first floor without messing up completely its design. I will try to find a good way to apply it but if you have some suggestions I will certainly accept them :). |
Current timezone is GMT Oct 9, 2026, 9:52:01 AM |
