Print at Aug 26, 2026, 6:15:09 AM
Posted by Puybaret at Aug 4, 2018, 3:24:59 PM
Re: Graphic error ALWAYS on the installer version
Antonio, it's not a question of being boring. There's no problem to help you but Facebook is simply not the place for support requests. You should also be a little more patient. Don't expect an answer about anything immediately after you post a question.
If you installed the program with /j3d.version=1.5.2 /os.arch=x86 parameters (did you?), the program will run in 32 bit and the max memory you can request will be 700 MB. So trying a higher value might simply make Sweet Home 3D fail as you tried.
Note also that -Xmx option must be followed by a number and a letter (m or g for MB or GB).
