Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: I see red! What happened? » » » » Post: Re: I see red! What happened? |
Print at Sep 6, 2026, 5:44:32 AM |
| Posted by Puybaret at Oct 19, 2008, 9:55:00 PM |
Re: I see red! What happened? Max sent me his file, but miserably I couldn't repair his file. Here's the solution I proposed him to avoid him to create again all his home: 1. Open the corrupted file 2. Click on plan to set focus in it, and choose "Edit > Select All" menu item (Ctrl + A) 3. Choose "Edit > Copy" menu item 4. Open a new home with "File > New" menu item 5. Click on plan to set focus in the new plan, and choose "Edit > Paste" menu item 6. Items will be still red in the new home, but all the walls and dimensions are nevertheless correct. Then, set again the texture of the floor, the texture of the walls, and replace each red object by one of the catalog. Once done, remove the red objects. To sum up make the "red" disappear. 7. Once there's no more red, you can save your new home. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 5:44:32 AM |
