Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Indicate price in furniture list » » » » Post: Re: Indicate price in furniture list |
Print at Sep 15, 2026, 7:05:07 AM |
| Posted by okh at May 31, 2018, 3:46:29 PM |
Re: Indicate price in furniture list Hi Lars, As you will see from the earlier in the thread, there is no interface for this as of yet. ..help me and in clear, simple steps .. how to activate price information visible in the display list... And as there is no interface, I am not sure the procedure should be called 'simple'. Activating involves editing a file installed and used by SH3D as described in Puybaret's post above (7471#38192). ..how to add prices to the furniture... Again, without an interface, you will need to edit 'manually, namely editing a FurnitureLibrary file (explained in several threads) or edit the entries in Home.xml...urgent need... For an urgent need, without going through the not-intended-for-end-user steps above, I suspect your simplest way of getting a price-list, is to select the furniture you need prices for in the furniture list, copy and paste to a spreadsheet (pay attention to locale/currency settings). And add prices to your items in the spreadsheet. Even with the latter method, there are a couple of cheats/workarounds. You could add the price in the name field with a special delimiter for the spreadsheet import (e.g. ยค) - or import the furniture putting the price in the creator field. Neither of which are very elegant, but well, if it is urgent... Maybe, if you could provide some more information about the scope of your project and how you intend to use the pricing, it would provide a strong case for implementing the feature with a nice interface... ok |
Current timezone is GMT Sep 15, 2026, 7:05:07 AM |
