Print at Oct 6, 2026, 4:58:16 AM
Posted by Puybaret at May 19, 2018, 1:41:10 AM
Re: Create slab or room with angled edges
Polylines are only used to annotate the plan and have no effect in the 3D view.
You should rather draw rooms but walls around a room are always vertical.
As a workaround, you may use thin boxes and rotate them horizontally to create such walls but you may find this too tedious if all the walls must be handled this way.
