Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: In need of assistance » » » » Post: Re: In need of assistance |
Print at Oct 9, 2026, 5:25:38 AM |
| Posted by dorin at May 10, 2018, 10:32:28 AM |
Re: In need of assistance1. You've made good progresses 2. On notepad You've right -it looks bad. Verify the notepad settings because don't interpret correctly the end of line and the spaces. You can use other text editor (LO writer or MSWord). 3. My advice is to NOT use any texture in that stage, only different colors. The user could set their own preferences after insert it in plan. 4. If You modify the name ONLY in mtl file of course You've loose the transparency; You MUST also modify the name in obj file (in text editor). e.g.: in Window.mtl #Produced by Art of Illusion 3.0.3, Tue May 08 14:32:53 EEST 2018 newmtl window illum 1 Ka 0.2 0.2 0.2 Kd 1.0 1.0 1.0 Ks 0.0 0.0 0.0 Ns 1.0 Ni 1.0 d 0.26666665 #this indicate the transparency in Window.obj #Produced by Art of Illusion 3.0.3, Tue May 08 14:32:53 EEST 2018 mtllib Window.mtl s 0 g Window usemtl window #this indicate which texture to use for next object v 0 0 0 v 0 0 10 ..... ..... etc Hope is useful. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 9, 2026, 5:25:38 AM |
