Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Hobby Shed / Couple's Cabin » » » » Post: Re: Hobby Shed / Couple's Cabin |
Print at Oct 16, 2026, 7:09:53 AM |
| Posted by AeowynFraser at Apr 22, 2018, 8:43:07 AM |
Re: Hobby Shed / Couple's Cabin I was looking at all the house files I have, and I've decided to go back and make a few adjustments to the the outside of the "Mini Cabin" (the 2-bedroom version). Below are the changes made. DISCLAIMER - Because of the file size (59.8 MB compressed), my computer will not let me get rendered pictures of this fully furnished. (I find that for some reason I can't get rendered pictures of files larger than 50 MB; that's another issue that probably has to do with the available memory on my computer or something, so I'm not going to go any further on that matter.) I do not want to right now make an unfurnished version (maybe later), so all of the following pictures are screenshots. ![]() Front aerial view. I added some arches and changed the columns (as well as added some additional ones) to the entrance and the terraces. Because of putting in additional columns to the entrance, I had to switch out the letters box attached next to the front door for the mailbox on a post out in front. I changed the roofing, and it now has my favorite green tiling. I also added shingles to the walls just under the roofings that match the columns, arches and railings. I believe I also fixed the height of the windows on both floors to be even with tops of the doors. ![]() Back aerial view. No changes to this part, just that through the windows you can see that the paintings on the walls are elevated (because of my raising the roof ).![]() Main floor floor plan. I shortened the built in cabinet near the stairs, which made it possible to widen the bathroom vanity, and I changed the mirrors. I also moved the doors a little to the laundry room so that they're 6 inches from wall adjoining the bathroom instead of ... I think I had them at about 3 inches away before ... I also changed the textures of the coat rack in the Entryway and to two of the couches in the Great Room. I adjusted the placements of the wall mounted TV, track lighting and paintings in the Great Room, and I removed a cabinet from the bathroom. No other changes made to this floor. ![]() Top floor floor plan. I added the sideboard, vase of lilies, and figurines on the wall near the Bedroom. I also adjusted the heights of the wall spotlights because of raising the roof. No other changes made to this floor. NOTE - The rest of the pictures are from the Virtual Visitor point of view, showing most of the changes previously described. ![]() Front entrance. ![]() Great Room taken from the corner near the doorway to the Entryway. ![]() Bathroom taken from between the toilet and the wall. ![]() Top of the stairs looking to bedroom doors. ---------------------------------------- ![]() |
Current timezone is GMT Oct 16, 2026, 7:09:53 AM |
