Print at Oct 17, 2026, 7:18:16 PM
Posted by Puybaret at Mar 23, 2018, 11:37:54 AM
Re: levels, floor thickness and wall heights
The elevation of a level is the height at which a floor of a level appears and where objects are placed.
The Compute walls option tries its best but as walls are not "glued" to rooms in the program, it can't work perfectly. Keep in mind that you can change walls directly with their modification dialog box, and that you can also split a wall with the Plan > Split wall menu item.
