Print at Oct 17, 2026, 7:19:04 PM
Posted by olek94 at Mar 22, 2018, 11:06:28 AM
Re: levels, floor thickness and wall heights
so the basement level height (-120) , plus the street level floor height, (-3 for a 3 thickness) are what declare the thickness of my "street level" (it is just a very small square in front of the entry, the rest of the basement ceiling is also the floor of the basic level of that house and located 70 cm higher.
that ceiling height comes from the level, OK the floor thickness of the 1st floor is added, or substracted, from the height of the leves table ?
I did try basebord to add those wooden decorative walls, at the first level (not 1st floor) but they did build on the basement wall, despite being entered in the room dialog,
I think possibly this is because there was no separate wall at that level, but I entered "compute walls" , what does that switch, ? it do "glue" the walls to the room surface ? it does not split the wall, obviously. Is it to be used from a room without walls only ?
Thanks and sorry for the added questions
