Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: SWT? » » » » Post: Re: SWT? |
Print at Jul 22, 2026, 5:19:12 AM |
| Posted by Puybaret at Mar 8, 2008, 8:32:00 PM |
Re: SWT? The MVC architecture of Sweet Home 3D allows to replace AWT/Swing by SWT without programming again all its model and its controller. Sweet Home 3D under SWT was even available in its early versions until 0.7 ; please read the end of my message http://forums.java.net/jive/thread.jspa?messageID=241470#241470 for more information. But if a Swing application's look and feel isn't correct under some Linux distributions, you should rather complain to Sun than think rewrite it with SWT. Maybe the required changes aren't that big. > The use of GTK would also negate the need to manually edit colors as .mtl files could then be included with the .obj files (as the .mtl file is automatically created by most exporters) Lack of support for .mtl files has nothing to do with Java, as Java 3D supports them. Sweet Home 3D should support them in the next version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Jul 22, 2026, 5:19:12 AM |
